GSH25SGRBSS GE Side-By-Side Fridge Is Hot
Robb235
Tennessee
GSH25SGRBSS
Model: GSH25SGRBSS
Had an issue with the coils frosting over. Traced it to a bad thermistor in the freezer that had resistance way out of range. While I was in there I just went ahead and replaced both thermistors in the freezer side. I also replaced the bi-metal thermostat. I forget which connectors I jumpered on the control board, but the heater element works and gets hot in a hurry. Also verified that resistance across the heater was within spec. Noted that the fan blowing across the coils in back of the freezer was working. I did NOT replace thermistor in the fridge side, because I don't know how to access it.
A month after I replaced the faulty thermistor (and other parts listed above), I noticed this morning that the fridge was warm, about 60 degrees. Freezer side is cold, around -2 according to my laser thermometer.
I have not checked if the coils are frozen over again, since freezer is currently full of food. Does that need to be the next step? What a pain unloading the freezer...
Can I measure resistance of the fridge thermistor at the control board? If so, how?
Robb235
Tennessee
Ok, so after watching some YouTube videos, I figured out how to test thermistors from the control board.
J1-5 to J1-2: 8.2K ohms
J1-5 to J1-3: Open (how?? I just replaced it...)
J1-5 to J1-4: 47k ohms
So when I replaced the freezer side thermistors, I used heat shrink bullet connectors to make the connections. I guess I must've made a bad connection somewhere. That or the thermistor already went bad?
You can check everything at the motherboard. Check for a broken wire between the connector and the thermistor. Here's the pinouts for the board:
WR55X10942-1.jpgWR55X10942-2.jpgGEMB-03 Defrost Test.jpgGEMB-07 Fan Thermistors.jpg
This is how I measure in the connectors:
Robb235
Tennessee
I redid the connections for the freezer thermistor. It read something like 6k or 7k ohms between J1-5 to J1-3, don't remember exactly, with everything at room temperature.
Fridge still seems to run constantly, so I guess we'll see in another month or so if my coils ice up again.
Robb235
Tennessee
Well, it's doing it again. Fridge side was warm 50ºF. Freezer side was around 0ºF. Not sure what else to do with this refrigerator, no idea what else I should replace at this point.
There's only the three parts that make up the defrost system, the heater, thermostat, and board. That's why I said it's simple. If the heater and thermostat are good the board is the only thing left.
Robb235
Tennessee
Measured the resistance of my three thermistors at the motherboard again.
J1-5 to J1-2: 8.4K ohms (laser thermometer said 55-60ºF in the fridge)
J1-5 to J1-3: 73K ohms (laser thermometer read between -6 and 0ºF in freezer)
J1-5 to J1-4: 84k ohms (again, thermometer read between -6 and 0ºF in freezer)
Why are both my brand new thermistors in the freezer reading so far off the actual temperature?
Robb235
Tennessee
Took measurements again just now.
Now I’m getting :
J1-5 to J1-2: 8.2k ohms
J1-5 to J1-3: 42k ohms
J1-5 to J1-4: 49k ohms
What gives...
That looks about right. 8.2K=56°F 42K=0°F 49K=-5°F It depends on how accurate your infrared temperature gun is and where you're shooting the temperature. Most infrared guns have a ±4°F The only accurate way to measure a GE thermistor is to place it in a small glass of crushed ice and just enough water to cover it. That will get the thermistor to 32°F. At 32°F the thermistor should have 16.3KΩ resistance. Those last measurements are close enough for me to say they're fine.
Maybe it's your connections since it's the two you replaced. They shouldn't keep the control from starting a defrost cycle. J1-4 is used to terminate the defrost cycle and unless it was open or shorted wouldn't stop the control from starting a defrost cycle.
