GSRC3QGXAFBB GE side by side - Frost build up in the ice chute the ice comes out
coline
ontario canada
GSRC3QGXAFBB
I am having a problem with frost build up in the ice chute the ice comes out most times but does get caught up at times. It makes snow all around the exit I clean it out but it makes more every time.
Make sure the flapper door is closing and closing fully.
GSRC3QGXAFBB
This is a Canadian only model and won't come up in most part searches.
coline
ontario canada
the ice build up is actually at the bottom of the ice maker itself. Its where it comes out to go into the chute around the blade that turns to either crush or cube. Any help please
Have a picture? Post it/them here.
If the dispenser flapper door is open, room air will migrate in and leave frost on the bottom of the bin and icemaker.
I have checked the door it seems sealed
00126820i01.gif #62 is closed/closing properly?....cause those pics look like warm and cold air are migrating back and forth from an air leak of some sort.
coline
ontario canada
I replaced flapper door and the actuator but it is still frosting its almost looks like water might be dripping down the top of the ice containor do you think it could be the ice maker leaking water
