FIXED GTD65EBSJ3WS GE dryer disassembly
wpearson
SC
GTD65EBSJ3WS
Look for a repair manual for GE dryer Model#GTD65EBSJ3WS.
GE service manuals are rare. The best you can probably do is the tech sheet (mini-manual). I checked but I don't have one. Are you looking for something specific?
On that style the top comes up first. There's a couple screws in the back of the top panel then slide the top panel back so it disengages from the clips on the front panel. Remove the two screws, one on each side, securing the top front panel to the side panels. Pull the top of the front panel forward then lift it off the bottom supports. You can access everything from there. The difference between your machine and the standard GE dryer is the top panel.
This video has a different top panel than yours but everything else is identical and comes apart the same way:
Thanks bigbuck! I was close. I forgot about the two screws going into the top where the door opens......LOL.
