GTD72EBSNWS GE Dryer no power
sancmarc1990
tyler texas
GTD72EBSNWS
My dryer stopped working. no power whats so ever. hooked uo multimeter to wall, i got 240, even checked the power cable. and all is good. dont know what to do. maybe there is a fuse internally idk yet. help if you can.
Check the voltage at the terminal block where the power cord is connected. In the same area is a fuse. Check it for continuity. If it checks good, can you post a copy of the tech sheet? I don't have that one.
Here's the fuse:
Hi, Did you figure your issue out? My dryer has just done the exact same thing. I used a multimeter and everything looks as it should.
