GTDP490ED0WS GE Dryer drum would not turn when start button is pressed
MisterC
Belle Chasse LA
GTDP490ED0WS
Drum would not turn when start button is pressed... stops humming when start button is released... Dryer has power but drum doesn’t turn when start button is remained pressed... I ordered the drum belt although I have not verified the problem as drum belt.
Does that hum sound like the motor is running, but the drum is not turning?
Or its just a hum sound and the motor isn't running? If that's the case--->See if you can turn the drum by hand both ways, if not, then you may have something stuck/jammed in the blower wheel keeping the drum the turning.
Here's the belt for your model:
Drive Belt WE12M29
When you click the part link to the belt you will see a video on how to remove the front panel to check for something stuck/jammed in your blower. Make sure you unplug your dryer first!
