RomanRepairs
- GTUN275GM1WW
- GE
- 1-5 years
GE washer dryer stacked combo unit Model # GTUN275GM1WW, Manu January 2017
Installed on the second floor, hallway closet, apparently lifted onto rear deck and moved to core of 2nd floor as the inside stairs are not wide enough to remove. Property is high grade rental in Canton
We have maintained the property for about 2 years or so. Unit has been working fine until a week or so ago
Tenant complained that unit was filling with water but not spinning or agitating.
Checked all the codes, changed lid switch as a quick fix, no change
Then I noticed a blocked motor error code
Checked the lid lock, fill valves, pump, drum to agitator clearance to make sure no jamming there, belt good, transmission gears and wax motor actuate but no initiation of spin or wash mode.
Removed the motor, tested in under power and it runs smooth. No pulley magnet damage. Replaced the motor speed sensor as a precaution.
Still getting blocked motor error code. Basically no change in operation. No error codes for control board.
