GTW330ASK4WW GE Washer Problem programming new board
Brianswensen
California
GTW330ASK4WW
I changed out a control board (WH18X28174) because the washer wouldn't turn on and would drain forever when plugged in. I can now run the washer with the new board in. The problem is it needs to be set to personality 2. From the instruction sheet that came with the board, only the rinse light should be on (second to to the right) to get personality 2.
This doesn't come up when scrolling through the personalities. On the sheet there are 14 different personalities, but there are only 10 light combinations when scrolling on the washer. Did I get a bad board? What is happening is everything is running fine but now only fills with a few inches of water, even on deep fill. Thanks for your help!
