GTW460ASJ4WW no lights and no controls after replacing fried control board
stnorton
GTW460ASJ4WW
I replaced the control board after finding that it had several burned components. After installing the new one, the front controls and lights are still unresponsive. There is a blinking green LED on the back side of the board, so I know it has power. Is there anything else I should check?
All new GE washer control boards come with instructions to set the personality ID, If you don't not set the personality ID per your model number, it will not work.
Did you not get the instructions with the new control board? Look in the bottom of the box it came in, or under the cardboard box fold.
Your personality ID is 11--->GTW460**J1 / J3 / J4 / J5 / J6
I'm attaching the instructions to set it.
  • GE_Control_Programming.pdf
stnorton
Thanks for the response Jake. I did get the instructions, however, the LEDs buttons and dials on the front panel do not function so I'm not even able to set the personality ID. I'm suspecting a DOA control board.
