GTW460ASJ5WW GE washer stuck in drain mode
Jason Cooke
I checked the drain pump it's working fine took it off... And done the 1/16" bit again same... The hose from there runs up to the control board so would it be in the board?? To run though again.... Plug washer in it turns on by itself in about 5 seconds on drain mode... I can hold pause button in and it will stop after probably 15 seconds and start again all lights flashing
What's the serial number of your washer?
If its prior to DG then you will need to order this kit: WH98R103510
He was just here... Transmission is leaking... And is leaking on board
What do you mean by that?
Jason Cooke
Will it work even when washer is trying to drain? There's nothing wrong with the transmission I don't think I took cover off and there's no oil or anything like that it's all clean... Repair guy said there was oil
MG161644G is the serial number
Your serial is not the one that needs the update!
Nope. So it looks like you will need a new control board.
Control Board
John Park
Florida
Hi Jake I have a top load ge washer with the model GTW460ASJ5WW that is Consistently pumping. The main control board is not turning on the start and pause button are not stopping the pump any ideas or info that you might be able to share ?
Hi John,
I'm assuming you need the exact same control board, but I have no confirmation on that since Jason never came back to update us on his. 😭
If the new control board doesn't fix it, you can send it back for a full refund, less shipping.
