FIXED GTW680BSJ5WS GE washer turns itself on
chatdad
Tennessee
GTW680BSJ5WS
Our three year old washer turned itself on and appears to want to agitate. You can hear water coming in. There are no lights on the control panel. The lid is not locked. You can spin the dial though nothing changes. It started dripping water last night after a spin and rinse cycle. Is it just possessed? Tried unplugging and that didn't work. It picked up where it left off. Reading the board my assumption is we either have a defective water fill valve or defective master board. Any ideas that a non-mechanical layperson can try before we decide if we want to spend the money on a service call or just chalk it up to the normal modern day appliance life cycle of 3 years?
What's the serial number of your washer? It will be on the model number tag. Then I'll check to see if you have any service bulletins addressing this problem.
Click here: Appliance Parts
Mejia2c
Gilbert Arizona
Hey Jake mine started to do this tonight. Same model. My SN is. GL163063G. I’d appreciate any help. I’ve only had this about 14 months.
Is it doing the exact same thing as chatdad's?
I did locate one service bulletin on yours, I'm attaching it below.
There is a update kit for this, part number is WH98R23015001 you can do it yourself it just plugs in and resets washer.
Mejia2c
Gilbert Arizona
Yeah exact same thing. I’m heading home right now. Going to go plug it back in and see if it continues trying to wash air.
kp2thebeach
Easley, SC
Hello! My model # GTW680BSJ5WS started doing the same thing this morning and it is only 15 months old. The serial # is FL157389G. Would I need the same reset part to fix mine?
Mejia2c
Gilbert Arizona
Hey I found a page that told me to unplug it. Tilt it forward at 45 degrees for a couple minutes. Then backwards. At 45 degrees. Then plug it in and let it do it’s thing. Could take up to 30 minutes. Mine took 10. Cause of this is over filling your washer and water getting to areas it’s not supposed to and thinking it needs to drain.
Los Angeles, CA
Mine is doing the same thing! It turned itself on, while empty. No lights on by the knobs and I can't make it stop without unplugging it! It's washing air and no buttons or knobs work or interrupt it. Lid isn't locked. There is water undernneath the barrel. Should I try that 45 degree tilt thing?
gma57
Kentucky
mine it doing the same thing. so i am going to try this,
JBELLS
Georgia
Hello, I could only find this blog regarding the issue we're having HELP!!! GTW680BSJ6WS AGITATES ON IT"S OWN when powered off still plugged in.
I did see a GE service bulletin update regarding several different models. The model closet to our model is GTW680BSJ5WS our model # GTW680BSJ6WS it wasn't listed on the Bulletin. Does that mean it will work for our model any wisdom how to handle this would be GREAT! I believe Jake you're the one that found this repair.
JBELLS
Georgia
Did you ever fix the issue?
Chuckakita
Kansas City, MO
Jake, my washer model GTW680BSJ1WS serial HG190576G turned itself on and the door latch does not lock. i unplugged the unit and that did not help. Also the digital timer is flashing. What might be the cause?
