Maybe we are not out of the woods yet.... AARRGGGHHH!!! I ran several normal loads, no problems.
Put in a heavier load of towels and came back to check and the system had 'paused' itself. No idea why since it was early enough in the cycle that it should not have been spinning or banging yet. I started it, came back a few minutes later it had paused itself again.
I tried to run a rinse and spin cycle and the drum is not moving, pump running, rinsing water coming in but drum not moving. Is there an overload error?
I put it in diagnostic mode and tried to turn on the impeller, a slight wiggle but no movement. Tried spinning the tub in diagnostic mode, no movement at all. No error codes are logged. Powered off and tried again. Still no luck.
The parts are all good. Is there a troubleshooting step for when the washer puts itself in pause by itself and when the stator/rotor stop moving? is it some type of safety or overload lockout?
