WheelmanM80
- GTWN4000M
- GE
- 1-5 years
These are all new issues which began occurring a month or so ago. I appreciate any input you have. Thank you for your time.
My GE top-load washer (GTWN4000M) recently began tangling clothes around the agitator. When this happens, it also usually doesn't enter the final spin cycle, so all the clothes are still very wet. At the end of the rinse cycle, I've noticed that the machine will agitate the load while the basin is empty of standing water. I don't know if this is normal or not. After I discover the tangled load, I untangle it and run a drain/spin cycle. It then works fine. The washer doesn't ALWAYS tangle clothes, but it seems that if the clothes are tangled enough, it doesn't enter the spin cycle. If there aren't tangled clothes, it acts normally.
After unloading the spun clothes and closing the lid. The washer thinks there are still clothes in the basin, and continues to agitate them. I'm not sure if it's legitimate agitation - the basin turns back and forth about 45 degrees, which then moves the agitator. (This doesn't seem to be strongly correlated to the clothes tangling...)
In addition, if the load shifts and becomes unbalanced, the basin slams around within the washer when the washer begins to spin to drain.
I'm at a loss where I should start repairs on this machine since there's so much that seems to be going wrong.
