GTWN4250D2WS GE Washer Only Runs Cold When Lid Closed
Ginger
Indiana
GTWN4250D2WS
GE Washer GTWN4250D2WS
Washer runs cold, when lid is closed. Runs all temps if lid is left open to fill. When Closing the lid a click sounds and then in runs cold only.
Do you think I need a new computer circuit board or valve?
Computer Board # WH12X10614
Water Inlet Valve WH13X10053
That's very odd, What happens when you set it on HOT ONLY? Does any HOT water come out at all? If not, use your multimeter to volt test the HOT water inlet valve solenoid connector and see if your meter reads 120 volts, if your meter reads 120 volts and no HOT water is coming out, then your water inlet valve is the culprit.
First make sure your water supply HOT and COLD have plenty of water pressure before the machine hookup.
Control Board WH12X10614
Ginger
Indiana
Thank you Jake.
I have all temperatures when the lid is up. On Hot - only hot water runs.......On Warm the water is warm.......On Cold the water is cold. Water pressure is good.
When I close the lid the tub fills with Cold water only.
That's very strange, I've never seen that happen before, so I don't know what to tell you to replace.
Hopefully another tech that has seen this before can tell you.
