GU1500XTLT3 Used replacement dishwasher now not working
waldreps
MN
GU1500XTLT3
Not sure of the age but model number is GU1500XTLT3 and serial number is FR0303130. Close dishwasher door and push normal and nothing happens. Push quick wash and nothing happens. Push clear and it will go through a drain cycle for a couple of minutes. Push air dry and the light will come on and so does the Refill Rinse Aid light. Hold the air dry button to lock the control panel and that works. Then pushing each button causes the control panel lock light to flash so the buttons on the control panel are actually working. Can't get it to wash. Let it sit for a day or so while trying it every so often and eventually the normal button or the quick wash button will work and it will start and wash the dishes like normal. It just seems to have a mind of it's own and works when it wants. I'm guessing you're going to say it's a bad control panel but figured I would post the question and see. Thanks for any help.
