GUD24ESSJ0WW intermittent problem with spinning and overflow issues
scott.pestka
Pinckney, MI
GUD24ESSJ0WW
We have a GE GUD24ESSJ0WW washer/dryer. 6 months ago the washer quit spinning. No error codes. 1st part replaced was water pressure sensor which did not fix the issue. 2nd part replaced was the Main Control Board and that fixed the issue. 6 months later now and the washer is having issues again with spinning and intermittent overflow issues. No error codes. Washer will spin fine in diagnostic mode. We replaced the lid lock switch and that did not fix the issue. All main board connections re-seated.
Appears to be intermittent because sometimes it will complete a full cycle just fine. I do not believe this would be a main board again. Not sure what to try next. Thanks for any input!
I have not worked on this model as of yet, but I did locate the tech. data sheet and Service Mode Entry Correction Bulletin and I'm attaching both below.
  • TB18-16.pdf
  • 31-16868 GE Mini Manual.pdf
