GW395LEPS Whirlpool range oven won't heat.
vness
Ontario
GW395LEPS
Oven and broil will not light/ glowbars do not light . Stove burners work.
I over boiled water and some spilled onto the burner. it took a little bit to dry, but when it did, the stove lit up but the oven did not. the over clicks lightly and then it sounds like it gives up.
The igniters do not glow.
when I lit the stove after the spill, there was a ever so sparkly sound, like a short circuit sound. the burner where the spill happened is the front left, which is just above the spark module. what baffles my mind is that the is no way for liquid to fall onto the module itself because it is separated by a solid steel plate... but i'm convinced that something triggered a spark to the wires that connect to the oven igniters.
Please help! I can't spend hundreds of dollars to fix this.
any advise would help.
