GY397LXUB02 Whirlpool range buttons still not bake, etc.
jimmytroy
nc
GY397LXUB02
Hey Folks,
RE: GY397LXUB02 Whirlpool slide-in range
Issue: buttons that don't work - bake, numbers, clean, warm, favorites, timer, light
buttons that do work - broil, clock, cook/hold, cancel
I tried a replacement control board WP8507P392-60 and symptoms stayed exactly the same.
I tried a replacement button membrane WPW10207933 and symptoms stayed exactly the same.
I tried a replacement temperature sensor 12001656 and symptoms stayed exactly the same.
What could be the problem?
the high limit switch
the door switch - the light comes on
the door lock
The problem is the keypad membrane. The WPW10207933 is not the correct one for your model.
Here's the keypad membrane for your model:
WPW10207928 Swtch-Memb
jimmytroy
nc
Hey Jake, thanks for your response.
Update: I have a second replacement keypad W10207928 (my first replacement keypad # was a typo).
On my original keypad and first replacement the faulty buttons were the same - bake, all numbers, clean, warm, favorites, timer, light.
That is why I tried the control board next, but to no avail.
So, with this second keypad: bake, clean, 1 and 3 now do not work.
So, it appears that the keypad is the problem, but Amazon keypads are not reliable out of the box.
My subsequent reading argues that membranes are a bit sketchy overall.
Can a membrane be repaired and/or tested prior to installation, is there a more reliable source for replacements?
Yes, don't buy appliance parts from amazon, too many members say the same thing.
Send it back to amazon and get a full refund, then order it from my link above to it in post #2, and you'll be back in business.
Do you see my link to it above in post #2?
Not that I'm aware of.
