HBL5055AUC Bosch Error code F04
vincej
Calgary
HBL5055
Bosch
How to get the lower oven out of the tin frame to access the door lock mechanism? The tin frame is already outside of the built in cabinets. Thanks.
vincej
Calgary
The lower oven finally got removed. The lock actuator motor appears to have come loose, rotated, and busted up the micro switch. The microswitch is obtainable but doing a test on the motor proved it did no longer work. The stove will be scrapped. This has been such a horrible thing to work on.
vincej
Calgary
Control panel is sitting out in the rain. It'll be going to the garbage too. A new stove is on order, one with left hand hinges.
Hi Vince,
Sorry you didn't get a reply, I would of helped you, but I've never had any training in Bosch appliances.
vincej
Calgary
I did retrieve the front control panel if anyone is looking for one. I'll try and remember to look here once in a while to see if someone is interested.
