HBL5750UC/08 Bosch Wall Oven. Broiler element comes on / stays on in all cook modes.
pfbzzz
us
HBL5750UC/08
Bosch
Bosch wall oven, microwave combo, HBL5750UC/08
Problem:
  • In any cook mode but off, broiler element comes on and stays on. This used to happen intermittently, now all the time.
  • Eventually the over-temp sensor will trigger and turn it off.
  • Turning oven to "off" will turn off broiler element.
  • Built-in diagnostics (from downloaded service manual) don't show any relevant faults.
  • Temp readings from sensors (again, using built-in diagnostics) seem accurate.
  • Using diagnostics to turn on broil element turns it on, but again, will never turn off.
All of this leads me to believe it is a stuck relay?
Question:
I've seen references to a "control/relay board" and a "relay board". I suspect one of these components.
Control/Relay board comes up as Bosch part #12022212. This board looks like it has many small relays on it.
Relay board comes up as Bosch part #00663802. This looks more like a power supply board than a relay board.
Should I replace the relay board?
That's the main relay board you would need, that one controls the heating elements.
You can order it here:
Control Module 12022212
