HBL8650UC/11 Bosch oven not maintaining proper temperature
VRepair
Moon
HBL8650UC/11
Bosch
Hi, I have a Bosch double oven which can not keep temperature correctly. Both ovens stopped maintaining proper temperature - sometimes it goes up to the set temperature, but then it does not maintain it. Also, sometimes they work fine and sometimes they do not. I am guessing it is either the control board or somehow both temperature sensor have failed, although I think it is the control board. Wanted to see what suggestions you have. Also, I wanted to see where is the control board located in the oven? Thanks
Bosch double oven. Model: HBL8650UC/11
Jeff, Rick, and Dan, and myself have very little experience on Bosch Ovens, and this is way above my payscale on yours.
Hopefully another seasoned Bosch tech will see this thread and shed some light on this for you.
I am not familiar with the functioning of Bosch models but on many other ovens both bake and broil elements heat during the initial preheat. After that mostly just the bake element cycles on and off to maintain the temp. If the bake element failed to heat at those times, it might cause your symptom.
LINK > Bosch HBL8650UC/11 Bake Element
(There's a separate one in each oven.)
There is a control board and also a relay board. I don't know where they're actually located but they're shown with the door latching mechanism in the parts list (see the following link).
LINK > Bosch HBL8650UC/11 Controls - exploded parts view
I think it fairly unlikely either the control or relay board would cause the exact same symptoms in both ovens *at the same time* (if that is what is actually happening). Normally each oven operates totally independently.
I don't know how you'd determine the problem on your model but you can try looking through the service manual at the following link for diagnostic tips. You might want to confirm the problem symptoms first?
LINK > Bosch HBL8650UC Service Manual
