- FEX831FS
- Frigidaire
I think I have a lot of info, but I lack the experience, hopefully a skilled person can tell me a quick fix!
I have a Frigidaire ELECTRIC combo washer/dryer station and have had problems with the dryer taking too long. It heats up, but just not hot enough. Here is the parts diagram
I ran the dryer with the door open, heat on high, and the exhaust vent detached for maximum airflow. After pressing the start button, I could see the element through the holes in the back of the drum and it began to glow red. The heat was high and things worked well. But after about 45 seconds the element turned off and wouldn't turn back on no matter how long I stood there. The drum would continue to spin, but the element would not turn on again.
This test was repeated with the same results.
This explains the long dry time...some heat initially but then it cools down and just spins.
I took the dryer apart and got to the back of the unit to see the heating element. In one 4 inch section on the top of the coil circle it was darker than the rest and there was an odd white ash-like powder on the back panel behind that part of the coil. Seems like a problem, but maybe it's normal?
Given the fact that the drum spins and the element turned on for at least 45 seconds, I have made the following assumptions: Both of the fuses are just fine, the electrical wiring to the switches works fine, and the airflow is unrestricted.
Does this sound like I simply need to replace the heating coil? Or else i'm thinking it may be a thermostat or thermal limiter (#33 & #36 on the parts list from the above link)
Please lend me any advice you may have...THANKS!
