- 106.51783412
- Sears Kenmore
- 1-5 years
I am trying to diagnose why my Kenmore Coldspot side by side is not producing ice. We are experiencing record high temps here this week so it has finally come to a head and I haven't been able to get a solid action plan together. Currently the ice maker just seems dead. It does not fill with water nor does it seem like it even attempts to (nothing can be heard). I am pretty certain the black water inlet is clear and not frozen or anything. I prodded with some wire and it seemed to only hit more rubber. I think I have a Sankyo Twist Tray Ice Maker and a voltage tester reads power in the wires going to it (I havent used my multimeter to get full readings) so It is powered as far as I can tell but the bail arm movement has no change whether raised or lowered.
Currently also the ice dispenser is not working as well. This has happened before and I found it to be a poor design in the wiring at the door hinge. Found and respliced the wires to get it working. Now when I check I don't see any wires severed but havent undone every inch electrical tape to fully know (I have a feeling at least this part is a wire issue).
I could really use the wiring diagram for my Kenmore Coldspot 106.51783412 but cant seem to find it anywhere. I found one that seems very close but there are a couple wires not matching up so I think it must be for a different model. That or anyone who knows how to troubleshoot the ice maker I'm fairly proficient if given good direction/steps to take. The fridge is only 3-4 years old with the initial home wire repair happening about 2 years into it's life cycle.
Oh and the water dispenser still works fine, I know those feeder tubes are separated but just thought I should mention.
Any and all help is greatly welcomed.
Thanks!!
Thanks!!
