- 1930s Magic Chef
I've got a couple of questions about an old stove. I've got a 1930's Magic Chef stove that I've now cleaned and adjusted the range valves on. Those are working great. The oven, however, is getting no gas at all. I assumed the 2 female nuts on the backside were a coupling and would turn independently so I could loosen one off the valve while the other remains tight to the pipe it's connected to. Unfortunately, both nuts turn when turning one and before working it anymore, I wanted to ask here to see what the best way to take this off is before applying too much pressure and breaking it. I've included some pics to you can see what I'm talking about. It's the first 3 pictures.
Also, there appears to be a small tap off the main line feeding the stove that comes out where the burner is and I'm wondering if it was added later because the burner itself is connected to the oven regulator/dial on the right side. I can't find any information on what this smaller gas line is for. This is on the last 2 pictures.
Thanks for any advice you can give.
