So I've been getting into it a bit more over the holidays. Doing some research on the parts and fixing refrigerators in general, I got the idea that the issue had to be either the thermal breaker(overload protection), start relay, or capacitor. After taking these parts out and testing them it seems the start relay is bad with no resistance in either the upright or inverted positions. I have tested the compressor itself and it reads ohms correctly.
I ran across those 3in1 overload start relay and protection parts and decided to give that a try but I'm not quite understanding how to wire it in correctly. There was a bunch of splices that I took apart and forgot to document but it lead me to believe it has been repaired before. These were splices from wires leading into/out of the fridge compartment, the compressor parts, and the drain pan heater.
I eliminated the drain pan heater (since it was shorted anyway) and am left with 3 wires leading into the fridge (black, red, white) and the (ungrounded) power cord.
If I wire
- black and one line wire of the 3in1 to the power line
- red, white and the other line wire of the 3in1 to the other power line
Everything starts working lights, fans, compressor but I understand that's going to make the compressor run non stop because it's not taking the thermostat into consideration. Everything else I've tried leaves something not working at all.
Attached the schematic that was handily attached to the back of the fridge and it seems I'm missing an aspect that the relay provided.
Any assistance to put me on the right path would be much appreciated!
Also, here are the parts I removed from the "Relay Package" -
- Motor Protection - MRA6988-341
- Start Relay - 3CR-204-181
- Capacitor - 35F997BA7 (189-227 MFD)
