Hi everyone . FPHD2491KF0 Frigidaire Dishwasher makes a lot of noise when draining water.
TomRu
California USA
FPHD2491KF0
Frigidaire
Hi everyone ! Dishwasher Frigidaire FPHD2491KF0 makes a lot of noise when draining water. the filters are clean and did (function) sterilization together with the cleaning agent. what would you recommend to see? what can break?
Make sure nothing hard like a piece of bone or plastic is inside the pump area making this noise.
If nothing is in there, replace the pump assembly.
LINK> Drain Pump Assembly
Video help to access the pump and to check inside...
jeff sr.
If you get a chance, let us know what you find/see.
jeff sr.
Hi . Thanks for the recommendation, we looked at this part, nothing is clear, nothing strange was found. Checked the hose and filters too, all clear. Do we need to replace this part? the hose through which the water descends is a little clogged, but the air passes.
I see marks like scrap marks.....kinda looks like something was in there at some point. Maybe fell out when things where taken apart? Maybe wore down enough and went out the drain? Put all back together and see what happens.
jeff sr.
I checked it before disassembly, there was noise when draining. and also, consequently, the dishwasher collects water when I haven't used it for a couple of days. you do not know what it is connected with? today I will check this pump myself, and completely clean the drain hose
Fill valve is not 100% closing and weeping in some water when the d/w is not in use = new fill valve time.
LINK> Fill valve assembly
If you find nothing inside but the draining noise comes back, would be worth trying a new drain pump.
jeff sr.
jeff sr.
how to check if there is something inside? do you happen to have instructions? we searched on the Internet, but did not find what we needed. Thank you 😊
Inside the drain pump and drain pump area??
If yes, just take things apart and visually check things out.
Inside the fill valve??
You cannot.
jeff sr.
