firefox15
- FC-33DT1HA
- 6-10 years
I have a unique chest freezer from Hisense. It's 75% freezer with a 25% fridge compartment. Items in the fridge compartment are getting too cold regardless of what I set the panel to. It doesn't seem to matter if I set it at 40 degrees or 50 degrees, the inside is consistently around 30-34 degrees with liquids freezing.
The compressor is nearly always running, and the freezer is the proper temperature (around 0-4 degrees). I defrosted the entire thing with no real change. Unfortunately, I cannot find a service manual or much at all to help with troubleshooting this. I have access to both thermistors, but outside of that everything seems mostly sealed. I can see the compressor (a Samsung) through the vents at the bottom.
I thought maybe changing out the thermistor in the fridge side could be worth trying, but since I cannot find a service manual, I have no idea what kind of thermistor resistance I would need, etc. Is there anything I can do to try to fix this, or should I just throw it in the trash? I cannot imagine it is worth calling for a repair on something nearly 10 years old, so I thought I would post here to see if anyone has ideas.
