- HMBC58ST
- Magic Chef
- 1-5 years
After plugging it in, the fridge cools to the set point and the compressor turns off.
-There is a refrigeration cycle indicator and it correctly indicates whether the compressor is running or not during this time.
-There is also a digital display of the temperature sensor and it correctly displays the temperature.
Within 12-24 hours, the compressor turns back on and doesn't stop running unless you unplug it from the wall.
-The compressor is running but the refrigeration cycle indicator is not showing that it is on.
-The digital display of the temperature sensor is still correctly showing the temperature (down to zero Celsius and then flashes "LL").
I resistance tested the temperature and defrost sensors and both appear to be working correctly.
Any ideas as to what's wrong?
