FIXED HMV3051U Bosch Microwave Keeps Turning On and Off
BigKetchup
Las Vegas
HMV3051U
Bosch
So we have this Bosch microwave that keeps turning itself on and off constantly. Sometimes it appears to work correctly for a few minutes when I plug it in after a long period of being unplugged but other symptoms have been that it constantly asks for the time or today when it was turning on, beeping, losing power, turning on, beeping, etc, in an endless cycle. I'm not sure where to go from here or if someone else had this problem and solved it.
I tested the magnetron and it appears to have continuity and testing the door switches and they seem OK as well (two have 0.04 ohms when closed and a third has the same when open).
What baffles me is why it's turning on and off repeatedly; it's getting power but losing it right away. Is there anything else I can test?
BigKetchup
Las Vegas
Update: I fixed it. There are three capacitors on the main controller board, two of which were bulging. I removed all three with a soldering gun and replaced them with three new ones. Now it's working as normal.
Here's a photo:
What I'll also say is that some of the buttons weren't working properly at first. Re-attaching the green ribbon that goes to the touch pad fixed it.
Excellent, good job.:)
