Hotpoint Fridge Freezer not cooling
Tinkerer1
UK
FF7190AEX
Hotpoint
Hi everyone. I have a Hotpoint Fridge Freezer FF7190AEX.
Basically, the freezer section isn't cooling so no cold air is going from the freezer to the fridge. The fan is still working. I have had the appliance switched off whilst I went on holiday, in case it needed defrosting. Upon my return, still no change. After an hour or two, the lights flash and it beeps continuously.
There's no visible sign of any ice build-up in the freezer - although I do remember this did build up in the past (when I had a lot of food in the freezer).
What can I check? Replace?
This is a European model which means we don't have any tech. data/model number information on it here in the USA.
But in general if the compressor is running and your not getting any frost pattern on your evaporator coil, that indicates you have a sealed system problem, and you'd need a tech to come out.
Put your hand on the top of it and feel if its warm/hot and vibrating.
