FIXED Hotpoint Washer HTW200ASK0WW making a scraping / squeaking noise when agitating
troye
Biloxi, Mississippi
HTW200ASK0WW
Hotpoint
Hi, had it for an year (bought used) and just started making this noise. Thanks for your help.
Corrected model number
WTW200ASK0WW does not pull up as good, recheck it.
Click here: Appliance Parts
That's a noise I have not heard before on this model. Unplug your washer and tilt the machine back and see if its coming from underneath. Remove the plastic belt guard, and take the belt off and turn the motor pulley both ways, and turn the transmission pulley both ways and see if one of them is making that sound.
#318 is the belt guard
#603 is the belt
#320 is the transmission
#620 is the motor
troye
Biloxi, Mississippi
Ok what fixed my noisy one, replace these 3 parts. 326, 325 & 606. Check your belt, you might need that too. Easy to replace, 15 min.
Ok, sounds good, glad to hear those parts you listed fixed it.(y)
