How much suction is the ventilation fan supposed to have
Rupper
Wisconsin
PLMVZ169HCA
Frigidaire
Model: PLMVZ169HCA
This is an over the range unit and mine does not have enough suction to hold a piece of paper at the grease filters, let alone suck any of the steam/smoke from the range while cooking. Am I wrong in assuming it should? Otherwise the fan is basically worthless. The grease filters are clean, as well as the charcoal filter, and the unit ductless/recirculating.
An OTR fan is often around 300 CFM....not overly power, but should hold a piece of paper or kleenex to the filter.
