How to access fuses, built-in Jenn-Air microwave
bethgrim
Seattle, WA
JMC7000
Jenn-Air
My Jenn-Air microwave died. No power to anything on the microwave, but the combo built-in oven works perfectly. I've seen other threads referring to testing various fuses but the instructions have been for over the range or counter top type appliances. How do I get to the fuses to test them on a built-in microwave?
bethgrim
Seattle, WA
JMC7000ADW
What's "it" that I'm pulling out? Microwave? Microwave and oven? How do I remove from the wall?
Correct, the microwave, that is the only way to remove the outer cabinet/shell.
Sorry, cannot see the install...may be some trim or such around the edges, might have screws. Your use and care manual or installation manual may have some info on this.
bethgrim
Seattle, WA
Thanks for the reply. I have the trim off but the microwave is attached (with inaccessible screws, as far as I can see) to metal framework also attached to the oven. I think the oven and microwave would both need to come out of the wall to get to the microwave. I don't think that's a one person job. There's nothing useful in the care manual and I don't have an install manual.
The microwave ( yours is incomplete ) has a seperate model# to the oven which would make it a seperate unit.
bethgrim
Seattle, WA
Not understanding your point. Even if the 2 have separate model numbers, they're still attached to each other.
2 model#'s generally means 2 seperate units....and the microwave model# doesn't show any oven parts, just the microwave.
bethgrim
Seattle, WA
They're still physically attached to each other. Unless I'm missing something, both need to be removed from the wall for me to access anything on the microwave.
bethgrim
Seattle, WA
Longer model number was in my first reply above, JMC7000ADW. Is that still not enough? It's all I can find.
Not comfortable removing the oven from the wall, potentially screwing something up on it for the sake of the microwave. I think I'll just buy a new counter top microwave.
All I could see if the partial one in the original posting.
Any model# on the oven(s)?
Manual doesn't indicate attached to the oven either.
