How to confirm bad door switch on FL Speed Queen
72farmer
alabama
LTSAOAWN
Speed Queen
The door will not open after the door light goes out on my Alliance front loader. I am trying to make sure before i order this door switch part#802317 that it is bad.I want to rule out control board as being the culprit.Help me under stand and check switch.it has 6 wires going to it.I under stand the 2 wires on the plunger operated door closed microswitch that part of the switch works fine.The other 4 wire plug numbered 2-5 on switch is what i have a question on.I also understand why 2 wires are needed to lock door latch.What do the other 2 wires do on the switch?How do i check this switch with a meter and which 2-5 terminal on switch goes to what?
This is a model I'm not familiar with, but you should have a tech. data sheet in the bottom on your machine.
72farmer
alabama
Please Help
There is no tech sheet in the bottom of my washer.I guess someone removed it before me i bought it at a auction.The model is Alliance LTSAOAWN.Please help!Please do a part#802317 search to see the switch.
I did a search for that part# and I don't see any picture of it.
72farmer
alabama
Jake thanks for trying to help me.Try this model Alliance #LTSAOAWN i found it on the washer.
