How to diagnose GE Washer WJRE5500G2WW motor doesn't spin?
lgct38
Walnut, CA
WJRE5500G2WW
My GE washer doesn't spin. I reset the motor but still didn't work. How do I know if the motor is bad?
Does then motor run after it fills in the agitate cycle?
First check the motor LED STATUS light. You'll need to remove the front panel on your washer and check the motor error codes. Shawn has a good webpage to show you how here: HydroWave GE Washer Repair Guide
Let us know what error code you get from the flashing light on the motor, and how many times it flashes.
Here's the motor for your model:
Drive Motor WH20X10058
Motor status is displayed through a series of flash codes from a green LED located on the front side of the inverter just above the motor. See if it's flashing a code.
Ok sounds good, yes let us know.
Per Shawn's site--->6 flashes – This means that the motor cannot turn. Clear the code and if the problem still exists follow these instructions. To check, this first remove the belt and attempt to turn the big pulley. If it turns freely both ways replace the motor. If the big pulley, is stuck the shifter needs to be replaced.
Here's the Mode Shifter & Shaft Assembly for your model, in case you need to order it:
WH38X10017 Mode Shifter & Shaft Assembly
There is a video in the Mode Shifter & Shaft Assembly part link that shows you how to replace it.
lgct38
Walnut, CA
I removed the belt and turned the pulley. It turned freely both direction. When I turned the pulley, it was loose before catching onto some sort a latch before the basket inside moved. it was like that both direction. Is this normal?
Which pulley? The motor pulley or the big Mode Shifter & Shaft Assembly pulley?
Then its a bad Mode Shifter & Shaft Assembly, if the motor pulley turns freely both ways.
lgct38
Walnut, CA
But according to the instruction on Shawn's instruction, if the pulley moves freely both ways, replace the motor, not the mode shifter & shaft. Please see below:
Yes, if the big pulley turns both ways freely, but you said your big pulley wasn't turning freely both ways, didn't you?
That's what I'm not understanding, if the big pulley turns both ways freely it should not be catching onto some sort a latch before the basket inside moved.
Did you first clear the error code to see if the problem still exists?
To clear the error code, turn the washer off. Then disconnect power for about 20 seconds. Next, reconnect power then open and close the lid five or more times within 12 seconds in the first 30 seconds of power-up.
lgct38
Walnut, CA
Yes, the pulley turned both ways. I meant the pulley turned a bit before engaging the basket inside to turn. If I continued spinning, both the pulley and the basket would spin smoothly. If I reversed it, it would act the same way. I also tested by removing the belt, turning the knob to "Drain and Spin Cycle", pressing "Start" button; after that, only the pump started, the motor did not spin at all.
Yes, I did that and the LED still flashed 6 times.
Got it! In that case the motor is the culprit!
