How To Disassemble Microwave To Install Latch...
troche
Virginia
Less than 1 year
I bought a Sears Kenmore Elite Wall Oven/Microwave combination and have been pleased with it so far. Recently, the right latch (if you are facing the unit and opening the door) on the microwave door broke. Sears sent me the part and after a week it finally arrived. I now have two choices - I can install it myself (which seems simple enough) or call a service person and wait another week or more without a microwave. Can anyone tell me how to install this part? I looked at the schematic (http://c.searspartsdirect.com/lis_png/PLDM/R1009032-00004.png) which seems simple enough but when I look at the microwave door itself I don't see any screws that allow me to access the latch part or any screws at all for that matter!! Any ideas? Thanks...
mrand
Dallas
I have the exact same situation... did you ever figure out how to replace the microwave door latch? Marc
mrand
Dallas
mrand
Dallas
We were right - item 77 is a thin piece of plastic on the side of the door which goes around the window and pops out relatively easily. Under it, there are a dozen screws that, when removed, allow the outer glass assembly to be separated from the inner glass/hinge/frame. The hinge and retaining screw is then accessible on the inner frame. It's disappointing that the latch is made so cheaply... I'm replacing my broken one and buying one spare for each side for next time.
