How to optomize settings for my new AC
Jeff Ornstein
Brooklyn, NY
Hello,
The other day I bought a new window air conditioner, a Frigidaire model #FAA084P7A from PC Richards, a large electronic chain in NYC.
I have a few questions on how to operate this ac the best possible way.
1. On the electronic temperature indicator, it says "60" (lowest value), but can go to I think 90. Is this number the desired temperature for the room, or is this what I am supposed to tell the AC what it is outside?. Really, I just don't know. It doesn't say in the instruction manual. I'm just a bit confused.
2. Fan speed. It says that the speed goes from 10-99. Currently, it is set at 99, the highest. I read that this can control the humidity. But what's the best setting? 50% of 99 (~50)...25%, etc?
3. This is an 8,000 btu ac for a room that is 19'x12'. The salesman said that this is the ideal size output. I neglected to tell him that I am on the top floor of my apartment building under a roof, and it definitely can get hot in the summer inside. Also, the room doesn't have a door, it has an open archway to another, but smaller room. So some of the cold air is escaping to the other room (which isn't such a bad thing).
Should I have bought a higher btu model?
4. It's 95 degrees out right now at 11:30 in NYC. Any help in trying to get the settings right is much appreciated.
Thank you
Jeff
Yes, the 60 and 90 degree settings are for your desired room temperature.
The 10-99 fan speed is just like the low, medium and high settings on it.
The high setting would be good for days over 90 degrees outside.
Yes, a higher BTU is always best, like a 10,000-12,000 BTU.
Jeff Ornstein
Brooklyn, NY
Thanks Jake!
Next time, I will definitely try to by a 10,000 btu ac (at least). The salesman told me that the 8000 btu was the correct one.
Oh well....like I said, maybe next time....
Jeff
Glad to help Jeff.:)
