HPS18BTHFRWW Compressor current draw only 0.45amps
bazar01
GA
Model
HPS18BTHFRWW
Hotpoint
Ref stopped cooling but compressor and condenser fan are both running.
When I measured the compressor current draw with a clamp meter, it read only 0.45amps.
Refrigerator label says 110-127VAC, 60Hz, 6.5 amps.
What could be the issue?
Thanks.
6.5 amps is the entire refrigerator....all at once.
What is the LRA on the compressor tag?
I tried to look up by your model#...most showed 7.5 to 10.0 LRA.
This would be .75 to 1 amp running....approx.
0.45 is low, might be an inefficient compressor not working hard, a system leak and low refrigerant gas will also allow the compressor to run but not work very hard and draw less current.
No frost at all on the evaporator/cooling coils?
LRA is 9.2 amps.
So running amps should be approx 0.90 amps of the compressor only.
No frost on evaporator.
= a major system problem. New refrigerator time or BIG $ repair.
bazar01
GA
I think the compressor has a bad valve.
I brazed a charging valve on the compressor so I can pressure and leak test. It held pressure of 80 psi for 24 hours.
I found an exact replacement new compressor.
I won't be able to work on it until first week of May since I will be on vacation for 3 weeks.
It's for a rental unit. I hope to fix it for $65 and 3 hours of sweat. I have the tools to replace it.
Inefficient then.
Keep us posted.
bazar01
GA
Got the brand new compressor off ebay installed today.
Triple evacuated using nitrogen and breaking vacuum with R134A up to 5 psi on low side.
She is cooling now and running at 0.78amps and low pressure of 8 psi.
Is 8psi a good low side pressure?
Thanks.
Closer to 0 is better, might be slightly over charged.
bazar01
GA
I looked at the refrigerator this morning and it made ice on the ice tray.
The compressor suction line was cold and sweating and there was no frost.
The compressor was running and it stopped 3 minutes after.
I think I will leave it alone for now.
bazar01
GA
Hi Jeff. Thanks.
I checked it again today and the compressor suction line has white frost about 8 inches before the compressor inlet. It has condensation/sweat 8 inches long into the compressor.
Is this good or bad? Is it time to weigh the refrigerant? I don't have a scale though.
I would purge out a little until that frost goes away.
In my area the temp will only get better and warmer....this would increase the pressures inside and cause more frosting/sweating.
Your welcome!
bazar01
GA
Update:
I purged a little out and saw the frost retreated a little,
I got the pressure down to about 1 psi and the frost fully retreated.
That sounds much better :)
