HVDR1040B Fridge not cooling, compressor starts every 2 minutes, start relay does not rattle.
Charlie409
New York
HVDR1040B
Magic Chef
Hello Everyone: Our refrigerator/freezer will not cool. The compressor tries to kick on every 2.5 minutes, but fails. The unit was purchased at Home Depot 3 years ago. The brand is Vissani, (which I think is owned by Magic Chef) in case that matters.
After reading several threads here, I removed the start relay, but was disappointed not to hear a rattle of any kind. Does that mean that the compressor has died?
I tried to remove the rear panel to see if the coils needed cleaning, etc., but it appears to be permanently glued shut. Is there anything else I can test, or am I the owner of a very large paperweight?
THanks!
Hi Charlie,
If the compressor start relay doesn't rattle, then you use a multimeter to ohm test it for continuity, normal would be 0-12 ohms.
Put your meter probes in the 2 parallel holes on it and it should read 0-12 ohms.
If its good, then your compressor is shot.
Charlie409
New York
Hi Jake,
I appreciate your suggestion. I'll buy a multimeter, perform the suggested test, and go from there.
THanks!
Ok Charlie, sounds good.:)
Keep us posted.
