HVM1750DM1BB GE Microwave - Exhaust fan and light stay on with microwave door closed
Saul
Rockwood
HVM1750DM1BB
The Exhaust fan and light keep running when I shut the door. The door switches read good when I shut the door, and the hood TCO is open like it should be, from what I read. I left a wire off the TCO and tried it to see if it would solve the problem, but it did not.
Would I be right in assuming the circuit board (RAS-0TR7HV) the hood TCO plugs into is the culprit?
Here's the part you need:
Saul
Rockwood
Thanks! Looks like a 200 dollar part? I guess I'll be buying a new microwave.
