sewingcybermom
- 550
- Sub-Zero
- More than 10 years
Good morning! We have a sub zero 550 that is warm in the fridge section. The freezer is at around 20 degrees and holding. The freezer knob is set to #4. The fridge is at 62 degrees and we cannot get it to cool down. It was recently moved, and has not cooled down after letting it sit for over 3 days powered off. We have replaced the dual sensor refrigerator control, part # 4201260 thinking that could be the problem. However, since starting it about 22 hours ago, it is still at 61 degrees. I have tested the fan in the fridge by opening the door and pushing the light buttons to mimic the door being closed and the fan runs. The only other thing that I do hear is that every little while, I hear a humming noise that gets a little louder for all of 5 seconds. Like something is trying to run but can't. Does anyone have a clue to our issue? The condenser is clean, and I can hear the unit running smoothly other than that hum that happens. The walls of the fridge seem like they are getting cooler, but I think it's my mind WANTING it to be cooling. Thermometer says 61 right now. We have not tried to re charge with freon. Is that something a tech should do or can it be done by the user?
