FIXED Ice dispenser facade removal
kblock
Simpsonville SC
SZD26VL
Amana
The foam insulated pad that goes on the flip door for the ice maker is not tight and as the ice melts an occasional drop of water falls into the drip tray which over time creates a mess. I am trying to remove the Dispenser facade on the front of the frigerator door but can not see how it is removed. There are no obvious screws under the drip tray or under some removable panel strip. From past experience I know sooner or later I will end up breaking the facade unless I can find out where the holding clips are located.
Thanks for any help you can give me.The part number is 12280005 for the facade.
kblock
Simpsonville SC
Hello, thanks for the quick response. The facade was held on just as you said with two clips located on the bottom about 2" from each corner. Flat head screw driver worked fine, I just didn't want to damage the trim piece. Regards kblock
Excellent, good job.:)
