Ice Maker KitchenAid KSRP22FN Side by Side
irondan44
south jersey
Having trouble w/ a KitchenAid KSRP22FN icemaker.
I have taken the ice maker unit out and jumpered "T" and "H". It starts to cycle then I remove the jumper and replace the unit. The ice maker then continues to refill and make ice until the ice bucket on the fridge door fills up.At that point the ice maker stops making ice and (here's the problem) it never starts making ice again. The ice maker fills and freezes but will not dispense at this point.
I've checked the LED codes on the ice level sensor and get the "2 flashes, wait a second, 2 flashes". Also found that with LED sensor flapper held down the LED remains "on solid" and with LED sensor flapper down and freezer door closed switch held in there is no LED lit.
Icemaker fingers are facing front at 10:00.
Any ideas?
irondan44
south jersey
To clarify my orientation: With ice maker motor facing me the fingers are at 2:00, as the unit sits in the fridge the fingers point to the front of the fridge.
Seems to me to be either a relay is not reset when ice bucket goes below full or that a water-frozen (?) solenoid is malfunctioning.
AC
Ok, 2 o'clock is fine.
Feel inside your ice maker tray, Can you feel ice in all the 8 cube slots? If so, then your water inlet valve solenoid is fine.
It would either be your optics malfunctioning or the ice maker module malfunctioning still.
I've seen both go out quite a bit in the last 8 years myself, even though the optics test can check good, you can still have an intermittent problem.
I would suggest ordering both the module and optics, then return the one you don't need, when you order parts from our links here, you always have a 30 day FULL REFUND policy, even if the part was installed.
Here's the optics for your model:
Manufacturer part#4389102 is RepairClinic item#921526
The optics can test good, but still malfunction intermittently, thats why I say order both, its fooled me too, were they tested normal, but then after I replaced the module, it was doing the same thing, then I replaced the optics and WHOA!!!
You see what I'm saying?:)
irondan44
south jersey
Does anyone have wiring schematics for the icemaker? I'd like to know a little more about what tells the icemaker to harvest. Seems to me there should be a low level in ice bin, closed freezer door, ice bin in place and frozen ice in the ice mould. Where are these circuits/switches integrated? Is it the icemaker, the photoeye?
irondan44
south jersey
Icemaker working again
Finally got the job done. The culprit was the motor assembly. I used to work around cam timers - and the unit is basically a cam timer.
Found the cause of problem thru trial & error - I hate that.
I shoulda been clued in by the fact that I could jumper out the motor unit, kickstarting it into producing ice, then it would run a little while and stop. In my old cam timer days this would tell me that the revolution of the cam never advanced to a 'complete' or 'home' position. The photo eye always displayed a good code but I thought it was bad cus I could always get the motor assembly to restart.
Btw - on the motor there's a delicate little (exposed) switch that either became out of alignment or pitted.
I hate performin pluck & chuck but it got the thing workin fast. And resolved background noise at home...
Excellent, good job being persistent and fixing it.:)
I hate trial & error too, but when I first started doing appliance repair 21 years ago, that was the norm for me as well, till I got the hang of it.:)
indyanne
Indianapolis
Thanks and sorry to hijack
I am hijacking this thread to say thanks for the trial and error. I've been troubleshooting my KSCS23INSS00 ice maker. After several tests of the optics and using the jumper to start the harvest several times, I think you have described exactly what is going on. Optics seem to be just fine.
The ejector can be set back to 2:00 home position using the jumper, and the mold fills up with water just fine on this manual reset. But, that's it -- the ejector never returns back to 2:00 on its own.
I will let it run on max cool today and see if I have cleared up the problem with the tinkering I have done. If it's making ice by tonight, great. If not, I'll replace the module.
I will be disappointed to have had this fridge only a little over a year and have to replace the module, but that's what it looks like I'm going to have to do.
Again, thanks.
