Ice Maker not getting water - can you help?
Battlestar60
Virginia
Where do I look?
Hello!
I have a Kenmore fridge/freezer. The ice maker is not working. It is not getting water.
I've replaced the water filter and the water inlet valve. I checked the water line to the ice maker and water it not getting past the valve. The door water dispenser does work, so that valve is working. I think the icemaker valve is ok too (it's brand new).
I'm thinking that whatever that sends the signal to the valve to tell it to open is not doing that.
Any advice on what I can check? There's got to be a little gizmo in there, is it the arm?
Can/should I try to remove the ice maker to look it over or test it?
I really appreciate any help you can give. I can post more info or photos if necessary.
Thank you!
We would need your model number first.
Click here: Appliance Parts
