Identifing Microwave TCOs
K.Connell
Florida
Model
ALD10D
Amana
I have numerous Microwave Thermal cut outs in my parts drawer. I need to replace a very weak Magnetron Thermal cut out (TCO). How do I determine a Magnetron TCO from a cavity, hood or any other TCO? There are different markings on all the TCOs. A magnetron TCO cuts out at a higher temperature then any other TCOs. Thank You in advance
I got LD10D2-P1329702M AMANA Microwave Commercial
The mag thermostat doesn't appear to show a temp on it...
Thermoprotector-R9900097-00636590.jpg Thermoprotector
I don't know of any rule of thumb about what temps are used where....I just match up the old one I have removed with the new one I want to use to replace it.
K.Connell
Florida
Thank you Jeff. So am I to understand that the microwave parts industries do not have any type of identification to tell the higher temp. TCO from the lower temp TCO? This means that the only way you can be some what sure if you have the correct replacement is to purchase one, or find another on a similar microwave.
First off what "microwave parts industries"?....most microwaves today are made in the same Chinese factory.
I read the temp rating on the thermostat before attempting to find a possible replacement from my collection.
K.Connell
Florida
Thanks Jeff for the tip. Now when I salvage a Mag. TCO I'm going to tag it as that before storing it in my parts stash.
Sounds like a great plan!
