Identifying an old Hotpoint Oven (so I can fix the timer and clock)
wcs2
NJ
Hi!
I'm new here and have an old Hotpoint wall oven that works (and looks) great, aside from the clock/timer. I'm trying to track down a manual for it, but that is proving difficult. It says it's Cat. No. 10RJ10 with Serial No. 9892025, but I can't find anything on that at all. My guess from what research I've been able to do is that it was made around 1957.
I'd love to get the clock working, but the schematic that doesn't really help me with this. I'd likely need a service manual to do it right. Can anyone here tell me more or point me in the right direction?
Here are some pictures in case it helps.
Timer repair co.
A service manual will not tell you how to repair the clock. At most it might describe how to remove it but It is extremely unlikely you will find a service manual for it so I think you should just get on your way trying to service it yourself.
BTW There are companies that specialize in repairing older mechanical clocks and timers. If you remove it you can sent it out for repair.
LINK > GEneral TIME RepairS
wcs2
NJ
Thanks for the link. I'd still like to get a hold of the user's manual and service manual. Any ideas where I can look?
wcs2
NJ
Oh wow, that's a surprise. At least GE just confirmed the date of manufacture for me, so I can lead a more targeted hunt.
sboudi2
Bettendorf, IA
Were you able to find the manual? I’m in a rental with this exact oven and I can’t figure out how to use the timer. I turned a knob and now it’s endlessly ticking/hissing.
wcs2
NJ
I never did. I was able to successfully get the timer back in shape (it needed new wires), but the clock and the timed cooking don't work. I haven't heard that noise you're hearing, but is it possible that the rotisserie is turning? Try pushing the button to the left of the timer and see if that stops the sound you're hearing.
Also (just in case this helps), the timer should point straight up to be off. You'll feel it gently snap into place when it's at Off.
lhebbe
Milwaukee wi
Hi!
View attachment 41818View attachment 41819View attachment 41820
Can you post a picture of the bottom stove element? Would be super helpful!
