IF50CM23NW Questions about start relay kit
bsaucer
Alabama
IF50CM23NW
This Idylis chest freezer has an unusual start relay on the compressor with a lot of screws and connectors. There are two wires that can plug into it, but I'm not sure which connector is which. I checked the ohms and found between 200 and 300 ohms between what is probably the start/run connectors. Compressor windings test OK. The unit kept clicking on and off (before I removed the part for testing). I'm not sure it was hooked up right to begin with. I think someone worked on it before.
Ok b,
If you can upload a photo or two of it, we may be able to tell you.
I couldn't locate the wiring diagram though, which we would need too.
bsaucer
Alabama
I have files attached.
Yes, I see why your confused. but the way you have it wired in the photo looks right to me.
I agree with you on that.:)
billbeachey
Berne, IN
I have an identical freezer that won't run. I have checked for power right up to the compressor, checked continuity on the compressor, etc. The problem seemed to come down to the start relay, so I replaced it with a couple of pennies to test it. It started immediately, but only ran for 5 seconds. I unplugged it and tried it again later with the same results. What could be wrong?
With a couple pennies???
Can you elaborate? I'm not sure what you mean.
billbeachey
Berne, IN
Thanks for your response. If you look at the pics earlier in this thread in the second pic, below the overload protector there is a small disc that is identified as the start relay in the service manual. It is about the size of a penny but thicker. Two pennies fit in there nicely.
Got it! Just for testing is fine to do with pennies.:)
The compressor piston inside the compressor has seized up and we call that a locked-up compressor.
I've run into 2 compressors in my area in the last couple weeks doing the same thing, only fix is to have the compressor replaced.
Glad to help Bill.:)
