dasherbravo
- IF71CM33NW
- -brand-
- 1-5 years
I have the same model freezer as Benzyoc had issues with back in Feb. of this year but I'm uncertain as to what his symptoms were so I am unsure if the fix provided by the Appliance Tech who responded, Dan O., would be the same for my issue. Link to Benzyoc's issue:
www.applianceblog.com
The freezer is not running- when I cycle power at the switch, I get about 5-10 seconds of a hum that sounds like it's wanting to start up but then it clicks and stops humming.
Is this the same relay combo kit fix as described at the above link or something different?
Again, this is an IDYLIS brand freezer-
I am attaching photos for reference if that helps- thanks in advance.
dasherbravo
FIXED - IF71CM33NW Idylis 7 cu ft freezer - Start relay
Which 3in1 do I need. My model has a Capacitor next to the compressor. The capacitor has a blue and brown wire. I’m assuming that the 3/1 will replace the capacitor? I’m not too sure. 1.7A 12A startup. I think it’s the 1/4-1/3hp hard start 3in1
dasherbravo
