FIXED IJ41001 Inglis Washer possible timer problem?
xento
IJ41001
My washer is a Whirlpool Inglis IJ41001. I suspect a problem with the timer but I'm not quite sure. The timer on the washer will not advance when it's on "delicates" but still working on "casual". I would appreciate any help with identifying the issue.
Thanks.
I found IJ41000 and IJ41001
On these newer plastic body timers we cannot even test for power to the timer motor to see if the timer is or is not at fault.
Might as well try one and if it doesn't not solve your problem you can send it back for a refund ( minus the shipping ).
whirlpool-timer-mallory-wp3948852-ap6008876_02_m.jpg LINK> Timer - IJ41000
xento
You're right, I typed the wrong model number. The right number is IJ41001. I ended up changing the timer and it fixed the issue.
Thanks a lot for your help.
Happy Holidays!
