ILVE range wont light
davidrcase
Missouri
UPN120FDMPBXLP
Less than 1 year
After hooking my range up to a propane cylinder i got a small puff of propane coming out the burners but nothing more. I would light for like 2 sesonds and then go out. I took the regulator off the back and when I turn the propane cylinder on I can hear gas coming through the stove side of the regulator. I've spoke to the manufacturer and the only regulator required is the one on the back of the stove so there is a line running directly from the regulator on the stove to a 100 gallon propane tank out site. If I bleed the system I'll get that little puff of flame again and again but no lasting flame, and the system has to be bled again to get the puff, it won't happen everytime I turn on the burner.
Please help!
Set the regulator for LP and not NAT.
davidrcase
Missouri
Is the model number, I’ve already converted the regulator to lp from natural gas, again this is an llve range
Yeah, we're not going to have any information on that appliance. Never heard of it. Did you check your regulator?
davidrcase
Missouri
When I remove the regulator I can get gas coming out the stove side? Is there any other way to check and see if a regulator is functional?
