Insinkerator Model 17-55
RonaldMetz
Cookeville, TN
My church has an Insinkerator model 17-55 and the stopper/magnetic switch has been lost. What are the options to return the garbage disposal to service since the stopper/magnetic switch does not seem to be available anymore?
You can bypass the magnetic switch in the disposer then plug the power cord into a wall outlet that's controlled by a wall switch or install your own wall switch between the outlet and disposer.
Older model ISE units didn't use a magnetic stopper but just a mechanical one. The ISE stopper part # was 1019-C and there was a KitchenAid version part # 4211474. Both appear to be discontinued. I'm afraid I don't know where you'd find either.
You could check with a local ISE service depot. They might have a used one still kicking around from a unit that was scrapped?
LINK > ISE Service Depots
The only other options I can think of is bypass the on/off switch and install a wall switch instead as Rick said. You'd then need to find some type of stopper to cover it while in use. Either that or replace the whole disposal with a new unit.
There are several ‘batch feed’ disposers still available.
LINK > Batch Feed Garbage Disposals
I did find one web site that says they have stock on the needed stopper. If you're interested I'd suggest you call to find out for certain. I do not have any previous experience with this particular company.
LINK > ISE Stopper @ SuppliesDepot
